chtMultiRegionSimpleFoam - Volumetric Heat Source - OpenFOAMV2212 - not working
Old   June 16, 2024, 05:12
Default chtMultiRegionSimpleFoam - Volumetric Heat Source - OpenFOAMV2212 - not working
Nayeem Bin Zahid
Nayeem12 is on a distinguished road
I am investigating a subchannel of Molten Salt Reactor. The design is essentially a graphite pipe, through which, heat generating molten salt is flowing.
For the heat generation, in ANSYS, I have simply added following equation in the flowing molten salt cell zone:
1.57 * 213.5e6 * sin((y*PI)/(3.96 [m])) * 1 [W m^-3]
Now for validation, I have extracted the exact mesh and imported to OpenFOAM, added exactly same boundary conditions, and for adding the heat source to the fluid, I have added an fvOptions to the fluid region with following lines:
energySource
    type            scalarCodedSource;
    active          true;
    name            sourceTime;
    scalarCodedSourceCoeffs
        selectionMode   cellZone;
        cellZone        fuel_region;
        volumeMode      absolute;
        fields          (h);
        fieldNames      (h);
        name            sourceTime;
        codeInclude
        codeCorrect
            Pout<< "**codeCorrect**" << endl;
        codeAddSupRho
            const scalarField& V = mesh_.V();
            const scalarField& celly = mesh_.C().component(1);
            scalarField& hSource = eqn.source();
            // Initialize min and max with the first element of celly
            scalar minCelly = celly[0];
            scalar maxCelly = celly[0];
            forAll(celly, i)
                hSource[i] = -(1.57*213.5e6*sin((3.14159*celly[i])/3.96))*V[i];
                // Update min and max values
                if (celly[i] < minCelly)
                    minCelly = celly[i];
                if (celly[i] > maxCelly)
                    maxCelly = celly[i];
            // Print out the min and max celly values
            Pout << "Minimum celly value: " << minCelly << endl;
            Pout << "Maximum celly value: " << maxCelly << endl;
            Pout << "**codeAddSup**" << endl;
        codeConstrain
            Pout<< "**codeConstrain**" << endl;
limitTemperature
    type    limitTemperature;
    active  true;
    limitTemperatureCoeffs
        selectionMode all;
        min    839;
        max    2400;
But the result is far from what ANSYS predicted. Even the temperature profile is completely different.
To check if I have added the boundary conditions properly, I have changed the scalarCodedSource to scalarSemiImplicitSource and added a constant specific heat generation term to the fluid region with following fvOptions:
scalarSource
    active  true;
    type    scalarSemiImplicitSource;
    scalarSemiImplicitSourceCoeffs
        volumeMode  specific;
        selectionMode   all;
        injectionRateSuSp
            h   (213.5e6 0);
limitTemperature
    active  true;
        selectionMode all;
        min    839;
        max    2400;
And did the same for ANSYS, and the temperature profile came out as perfectly same.
This led me to believe I am possibly doing something wrong with the sinusoidal volumetric heat source I am using in fvOptions?
Nayeem12 is offline   Reply With Quote
chtmultiregionsimpefoam, conjugate heat transfer, openfoam 2212, volumetric heat source
MapFields utility for staggered grid saeed jamshidi OpenFOAM Running, Solving & CFD 17 January 23, 2024 12:36
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
