April 19, 2024, 03:46 |
strange behavior of BC mappedValue
Sebastian Thaler
Rep Power: 2 |
Hey,
i am trying to connect two patches with the mapped condition. I am testing the BC on a simple rectangular duct with laminar flow. I am trying to connect the upper and lower side. It works fine with cyclic, but this condition does not work on my actual model. So i am trying the mapped type. Here the BC part of blockMesh: Code:
boundary ( yMax { type mapped; neighbourPatch yMin; //matchTolerance 0.1; transformType translational; separation (0 0.05 0); faces ((3 7 6 2)); } yMin { type mapped; neighbourPatch yMax; //matchTolerance 0.1; transformType translational; separation (0 -0.05 0); faces ((1 5 4 0)); } xMax { type wall; faces ((2 6 5 1)); } xMin { type wall; faces ((0 4 7 3)); } inlet { type patch; faces ( (0 3 2 1) ); } outlet { type patch; faces ( (4 5 6 7) ); } ); Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type flowRateInletVelocity; meanVelocity 5; profile laminarBL; //type fixedValue; value uniform (0 0 5); } outlet { type zeroGradient; } ".*" { type noSlip; } yMin { type mappedValue; value uniform (0 0 0); } yMax { type mappedValue; value uniform (0 0 0); } #includeEtc "caseDicts/setConstraintTypes" } |
Strange STL when using cuttingPlane | C-L | OpenFOAM Post-Processing | 2 | September 26, 2017 06:44 |
Strange flow partern (Reverse Flow) in fluid past circular cylinder problem at exit | HectorRedal | Main CFD Forum | 9 | June 9, 2016 19:14 |
[blockMesh] Strange non-hexahedral cells? | maka15 | OpenFOAM Meshing & Mesh Conversion | 3 | May 19, 2016 09:56 |
Strange residuals behaviour | xxxx | Main CFD Forum | 1 | July 13, 2013 15:40 |
Strange boundary behaviour using interFoam | Andrea_85 | OpenFOAM | 11 | January 22, 2013 16:09 |
