MRF Simulation of Radialpump unsure of right Boundaryconditions |
April 5, 2024, 07:47 |
Daniel
Rep Power: 2 |
Hello users,
my plan is to to a MRF Simulation of one blade of a Pump with cyclic conditions. Note the Point (0 0 0) ist not located at the patch of the inlet, its +50 in z above. Im using the SpalartAllmaras turbulence modell with simpleFoam solver. This is the Frame: Runner2.jpg on the bottom the inlet (IF_LAUF_SAUGROHR) at the top the outlet ( IF_LAUF_LEIT). Rotation in pos in z achsis with following boundary conditions: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 1e-5; boundaryField { IF_LAUF_LEIT { type calculated; value $internalField; } IF_LAUF_SAUGROHR { type calculated; value $internalField; } "(cP_cyclicA|cP_cyclicB)" { type cyclic; } "(NABE|KRANZ|SCHAUFEL)" { type nutUBlendedWallFunction; value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nuTilda; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 7.5e-05; boundaryField { IF_LAUF_LEIT { type inletOutlet; inletValue $internalField; value $internalField; } IF_LAUF_SAUGROHR { type fixedValue; value $internalField; } "(cP_cyclicA|cP_cyclicB)" { type cyclic; } "(NABE|KRANZ|SCHAUFEL)" { type fixedValue; value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { IF_LAUF_LEIT { type fixedMean; meanValue 0.0; value uniform 0.0; } IF_LAUF_SAUGROHR { type zeroGradient; } "(cP_cyclicA|cP_cyclicB)" { type cyclic; } "(NABE|KRANZ|SCHAUFEL)" { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { IF_LAUF_LEIT { type zeroGradient; } IF_LAUF_SAUGROHR { type cylindricalInletVelocity; axis (0 0 1); origin (0 0 -50); axialVelocity constant 10; radialVelocity constant 0.0; rpm constant 800; value uniform (0 0 0); } "(cP_cyclicA|cP_cyclicB)" { type cyclic; } "(NABE|KRANZ|SCHAUFEL)" { type noSlip; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object MRFProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // MRF1 { cellZone internalMesh; active yes; // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches (); origin (0 0 -50); axis (0 0 1); omega 83.775804095728; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 7 ( IF_LAUF_LEIT { type patch; physicalType patch; nFaces 3182; startFace 762848; } NABE { type wall; physicalType wall; nFaces 7155; startFace 766030; } KRANZ { type wall; physicalType wall; nFaces 7924; startFace 773185; } SCHAUFEL { type wall; physicalType wall; nFaces 14883; startFace 781109; } IF_LAUF_SAUGROHR { type patch; physicalType patch; nFaces 2230; startFace 795992; } cP_cyclicA { type cyclic; inGroups 1(cyclic); nFaces 10351; startFace 798222; matchTolerance 0.0001; transform rotational; neighbourPatch cP_cyclicB; rotationAxis (0 0 1); rotationCentre (0 0 -50); } cP_cyclicB { type cyclic; inGroups 1(cyclic); nFaces 10351; startFace 808573; matchTolerance 0.0001; transform rotational; neighbourPatch cP_cyclicA; rotationAxis (0 0 1); rotationCentre (0 0 -50); } ) // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // This application/dictionary controls: // - optional: create new patches from boundary faces (either given as // a set of patches or as a faceSet) // - always: order faces on coupled patches such that they are opposite. This // is done for all coupled faces, not just for any patches created. // - optional: synchronise points on coupled patches. // 1. Create cyclic: // - specify where the faces should come from // - specify the type of cyclic. If a rotational specify the rotationAxis // and centre to make matching easier // - always create both halves in one invocation with correct 'neighbourPatch' // setting. // - optionally pointSync true to guarantee points to line up. // 2. Correct incorrect cyclic: // This will usually fail upon loading: // "face 0 area does not match neighbour 2 by 0.0100005%" // " -- possible face ordering problem." // - in polyMesh/boundary file: // - loosen matchTolerance of all cyclics to get case to load // - or change patch type from 'cyclic' to 'patch' // and regenerate cyclic as above // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync false; tol 1e-4; // Patches to create. patches ( { // Name of new patch name cP_cyclicA; // Dictionary to construct new patch from patchInfo { type cyclic; neighbourPatch cP_cyclicB; // Optional: explicitly set transformation tensor. // Used when matching and synchronising points. transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 -50); rotationAngle 51.428571428571429; // transform translational; // separationVector (1 0 0); // Optional non-default tolerance to be able to define cyclics // on bad meshes matchTolerance 1E-4; } // How to construct: either from 'patches' or 'set' constructFrom patches; // If constructFrom = patches : names of patches. Wildcards allowed. patches (cyclicA); } { // Name of new patch name cP_cyclicB; // Dictionary to construct new patch from patchInfo { type cyclic; neighbourPatch cP_cyclicA; // Optional: explicitly set transformation tensor. // Used when matching and synchronising points. transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 -50); rotationAngle -51.428571428571429; // transform translational; // separationVector (1 0 0); // Optional non-default tolerance to be able to define cyclics // on bad meshes matchTolerance 1E-4; } // How to construct: either from 'patches' or 'set' constructFrom patches; // If constructFrom = patches : names of patches. Wildcards allowed. patches (cyclicB); } ); after simulation the solution confuses me Runner.jpg Runner3.jpg it looks like nothing is coming out of the outlet patch and everything is only rotating in the frame.... Ive tryed so many combinations of other boundaryconditions. but non of them worked. This is no physical right result. there has to be an outflow of the outlet patch. Pls can anyone help me? |
boundary condition, cyclic boundary condition, cylindrical mesh, mrf simplefoam, rotating boundary |
simpleFoam: Influence of MRF region dimensions on simulation results | Krao | OpenFOAM Running, Solving & CFD | 4 | March 29, 2022 21:33 |
Divergence of ducted propeller simulation using MRF simpleFoam | Krao | OpenFOAM Running, Solving & CFD | 1 | January 13, 2020 09:35 |
Periodic boundary conditions for moving reference frame (MRF) simulation) | guebelib | STAR-CCM+ | 1 | April 15, 2015 06:55 |
Weird results in MRF simulation of stirred tank with a steady state k-w SST model | aminem | OpenFOAM Running, Solving & CFD | 2 | January 3, 2015 11:21 |
MRF simulation : continuity residual high as 0.4 | guru | FLUENT | 2 | February 7, 2005 09:33 |
