what pattern does decomposePar follow to divide surface points among processors |
March 14, 2024, 03:02 |
Mohsin
Rep Power: 3 |
When decomposePar is run, it divides the original mesh into multiple folders named processorN (N=0,1,2,3..)
In original mesh, which is at constant/polyMesh We can find out the points/nodes ids related to a particular bounary patch by using boundary file and faces.gz file. But when its divided in many folders, the the node ids in paces.gz start from zero again and numbering is no longer same as the original faces.gz. So, its not possible to use files processorN/constant/polyMesh/boundary and processorN/constant/polyMesh/faces.gz to find out the absolute node ids related to a particular boundary patch. So, does any one know of a pattern in which decompose points among multiple processors? Or is there any other easy way to find out absolute node ids in each processor? |
March 16, 2024, 08:43 |
Mark Olesen
Rep Power: 40 |
The various cell/face/point ProcAddressing files give the correspondence between the serial view of the mesh and the rank-local mesh. So this could serve as one view of the global numbering. Another view could just be to use the rank-local offsetted numbering such as used in globalIndex and polyMesh globalMeshData. It is frequently this view of global numbering that is the more useful version. In fact, you will find a whole series of gather/scatter routines attached to globalIndex for thus reason.
decomposepar, polymesh |
Error in gmshToFoam on ESI v2106 | siefer92 | OpenFOAM Programming & Development | 4 | July 17, 2021 06:11 |
[snappyHexMesh] snappyHexMesh generates not planar surface | krzychu111 | OpenFOAM Meshing & Mesh Conversion | 2 | April 23, 2020 17:38 |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 10:17 |
[ICEM] Surface mesh does not follow node spacing | findtheinvisiblecow | ANSYS Meshing & Geometry | 7 | August 26, 2014 12:17 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
