"Cannot find patchField entry for allBoundary" - when setting two inlets in interFoam
Old   February 25, 2024, 11:56
Default "Cannot find patchField entry for allBoundary" - when setting two inlets in interFoam
Oscar Kail
oscarkail is on a distinguished road
Hello there,
I'm currently adapting a multiphase simulation project using interFoam by Jozsef Nagy to have two inlets. Despite changing all relevant files I can see (in the mesh folder: blockMeshDict, surfaceFeatureExtract, snappyHexMesh and then in the case folder: setFields, alpha.water, U and p_rgh) to have not just inlet but instead to have inlet-1 and inlet-2, I can't seem to find my self around the error message "Cannot find patchField entry for allBoundary".
Does anyone have any experience with this sort of error message (allBoundary)? It further explains "file: 0/alpha.water/boundaryField at line 25 to 58." which is essentially all lines within the boundaryFields section of case/0/alpha.water
Any help is much appreciated and thank you very much in advance for your help!
P.s Here's the case folder if it helps:
https://drive.google.com/drive/folde...6U?usp=sharing
oscarkail is offline   Reply With Quote
Old   February 26, 2024, 04:16
Yann
Yann will become famous soon enoughYann will become famous soon enough
This message means you have a patch named allBoundary in your mesh, but the solver cannot find the boundary condition for this patch.
If you are not supposed to have an allBoundary patch, then something must be wrong with your mesh.
Otherwise, you need to specify boundary conditions for this patch for all variables in the 0 directory.
Regards,
Yann
Yann is offline   Reply With Quote
Old   March 7, 2024, 05:36
sameer
sc369 is on a distinguished road
am facing the same issue
sc369 is offline   Reply With Quote
allboundary, openfoam, patchfield boundaries
Cannot find patchField entry for AMI gart04 OpenFOAM 1 March 17, 2023 03:35
Foam fatal error : cannot find patchField entry when I use snappyHexMesh in parallel Adak OpenFOAM Running, Solving & CFD 0 January 18, 2023 09:58
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
