Open foam Tutorial - Incompressible Fluid Dynamics
Old   January 3, 2024, 14:38
Default Open foam Tutorial - Incompressible Fluid Dynamics
Burhan Göktürk
GokturkBurhan is on a distinguished road
Hi everyone, this is my first thread.
I want to do thrust analyze for uav propeller with openfoam but I dont know openfoam very well. For this analyze, I need to work on compressible fluid. I didn't found compressible tutorial case in files. But we have incompressible tutorial. Can I change it and how can I do this. Or can I found similar files on web ?
İf this topic was discussed in forum, I m sorry in advance.
GokturkBurhan is offline   Reply With Quote
Old   January 5, 2024, 03:17
Domenico Lahaye
dlahaye is on a distinguished road
Please look for the compressible flow tutorials in the OpenFoam tutorials. Depending on the distribution and set-up that you are using the following commands
tut
cd compressible
take you there straight away.
Alternatively, you browse e.g. https://github.com/OpenFOAM/OpenFOAM...ster/tutorials
Please give it a look and post question here.
dlahaye is offline   Reply With Quote
#cfd, #openfoam, #propeller
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
