[mapFields] - Changing mesh fields from 2D to 3D
Old   January 3, 2024, 06:16
Red face [mapFields] - Changing mesh fields from 2D to 3D
Dasha
DashaSh is on a distinguished road
Dear All,
I need to modify the field calculated in the 2D case to the field for 3D geometry.
I calculated a simplified case for a wedge at 5 degrees, now I would like to test the same on a more complex wedge that has a rectangular shape in 3D.
Could someone tell me if this is possible to do? The information I found about mapFields does not give any success. cuttingPatches, if I understand correctly, do not apply to my case. I am attaching a image of what on my mind
https://imgur.com/a/8WcwukU
DashaSh is offline   Reply With Quote
Old   January 11, 2024, 02:33
Dasha
similar problem
Generating real 3D data from axis symmetric wedge data for cone
mapfields, mapfieldsdict, wedge
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 19:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
