How to add BrownianMotionForce in cloudProperties in OpenFOAM 10
Old   December 19, 2023, 11:32
Default How to add BrownianMotionForce in cloudProperties in OpenFOAM 10
W Zhang
wr_z is on a distinguished road
Hello Everyone. I would like to simulate the capture of the very small number of Lagrangian droplets mixed in the gas on the cylinder using Eulerian solver pimpleFoam for the gas. It is one-way coupled. I want to add Brownian motion force in the cloudProperties. But there are some errors. Could anyone else give me some help. Thanks in advance.cloudProperties.txt
wr_z is offline   Reply With Quote
Old   December 20, 2023, 06:21
atul1018 is on a distinguished road
Hi
I think you can't do particle tracking with just pimpleFOAM. You must be using some solver based on the pimple algorithm for the fluid phase. I have used DPMFoam long ago for my simulations to track particles in turbulent flow. I assume the cloudproperties file is similar to kinematicCloudProperties in DPMFosm. In the new version, they might call DPMFoam something else. May I ask which solver are you using?
From the couldProiperties file you shared, i see that you can include dispersion model, which gives particle some stochastic motion. So if you mean turbulent dispersion by Brownian motion force, then you can simply use dispersion models. There are mainly two options (in DPMFoam):
StochasticDispersionRAS
GradientDispersionRAS
PS: if you are interested in particle tracking in OpenFOAM then you might wanna read this publication. Things will be much clear to you
https://www.mdpi.com/2311-5521/7/10/337
Good luck
Atul
atul1018 is offline   Reply With Quote
Old   December 20, 2023, 06:54
W Zhang
Hi
Thanks so much for your reply. I am using the pimpleFoam for the continuous phase gas, and the lagrangian tracer for the droplets, it is a one-way coupled and laminar flow.
I can add drag, gravity, pressureGradient in the cloudProperties. But the drag, gravity, pressureGradient are in path: a: OpenFOAM-10\src\lagrangian\parcel\submodels\Momentum\Partic leForces,BrownianMotionForce is in path:b:OpenFOAM-10\src\lagrangian\parcelTurbulence\submodels\Therm odynamic\ParticleForces.
Best regards,
brownian, cloudproperties, pimplefoam
How to add WSGGM model to OpenFOAM HosamAlrefaie Main CFD Forum 0 October 24, 2021 09:50
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 09:23
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
