How to initialize flat interface with setExprFields (and "complex" mesh) ?
Old   November 15, 2023, 06:47
Default How to initialize flat interface with setExprFields (and "complex" mesh) ?
ALN
ALN
ALN is on a distinguished road
Hi, I would like to initialize a flat interface in a case with real bathymetry and cartesian mesh (generated with cfMesh). Some of the cells are wobbly, so interface is not flat. My idea is to put an alpha (phase volume fraction) proportional to the height of my interface in the cells (for example if the z_interface crosses the middle of the cell, alpha=0.5).
To do that, I would like to use setExprField (https://www.openfoam.com/documentation/guides/latest/doc/openfoam-guide-expression-syntax.html) . The trouble is : I can not find a way to access to the coordinates of nodes.
I try to put something with pts().z() in expression but this error appears :
--> FOAM FATAL ERROR: (openfoam-2206)
Mismatch between field-mask geometric type (cells) and
expression geometric type (points)
which makes sense. How to get pts().z()[0] for example ?
Many thanks for your attention !
ALN is offline   Reply With Quote
Old   November 16, 2023, 07:03
ALN
ALN
Finally, I find a way to do what I want with setAlphaFieldDict. The file looks like this :
field "alpha.water";
type composedFunction;
mode add;
composedFunction
    plane
        type plane;
        origin (723480 7594560 0.);
        normal (0 0 -1);
and it is activated with setAlphaField
initialisation, interface, openfoam, pre-processing, setexprfields
