SnappyhexMesh warning errors (I wish to eliminate them! completely!) |
November 14, 2023, 07:24 |
Biku
Rep Power: 4 |
So I am learning snappyhexmesh. I am able to get a decent looking mesh but I get the following warning errors during the SHM process. I have not turned on the layers addition just yet.
--> FOAM Warning : From function Foam::treeBoundBox::treeBoundBox(const Foam::UList<Foam::Vector<double> >&) in file meshes/treeBoundBox/treeBoundBox.C at line 135 Code:
--> FOAM Warning : Displacement (1.40188e-06 -1.34616e-06 -1.30598e-13) at mesh point 6658 coord (0.0191844 -0.0654924 0.755) points through the surrounding patch faces I am not able to make grids ariund simple cylinders using SHM without either of those warning popping up! I have been trying for 2 weeks but the number SHM iterations I have run is very less due to resource limitations. So I request you guys to advice me. The generated mesh does look decent but I want to turn off these warnings and want to know what causes them. Some good pracitices to follow etc. I have yet to dwell into complex stls. I have attached my test case on which I am learning. Using OF 5.x. https://drive.google.com/drive/folde...usp=drive_link |
November 14, 2023, 08:03 |
Biku
Rep Power: 4 |
received the treeboundbox warning when doing the snappy in parallel. The displacement error is when I do a serial execution of snappyhexmesh .
snappyhexmesh |
Caffa 3D code | Waliur Rahman | Main CFD Forum | 0 | May 29, 2018 00:53 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
