Can cloudProperties be changed during runtime? |
October 16, 2023, 15:23 |
Carl Kohrs
Rep Power: 7 |
Simple as the title: I need to change temperature, mass flow and perhaps other properties during runtime based on an external calculation (i.e. I will not know what the properties will be at certain times before starting the simulation). I'm using OpenFOAM 10 and buoyantReactingFoam.
October 22, 2023, 14:24 |
Carl Kohrs
Rep Power: 7 |
As a workaround I can stop the simulation (at certain endTime) and change the T0 of each cloud. This will be slower but better than nothing and it also means I can run my external calculation loop independent of the openfoam sim, rather than in a custom openfoam library.
However now I've run into a different problem which will slow down my simulation significantly, I can't restart the simulation with clouds after I've run it in parallel, with the following error. Code:
Size of origProcId field 0 does not match the number of particles 67 |
Modifying multiphaseReactingEulerFoam - Duplicate entry in runtime selection table | Andrea1984 | OpenFOAM Programming & Development | 7 | August 19, 2024 14:26 |
[snappyHexMesh] stringing of feature edges | Hr_kules | OpenFOAM Meshing & Mesh Conversion | 0 | July 22, 2022 08:30 |
Duplicate entry alphaContactAngle in runtime selection table fvPatchField | Roesch | OpenFOAM Programming & Development | 2 | January 12, 2021 03:35 |
Problem in3D model processing | mebinitap | OpenFOAM | 2 | December 12, 2014 04:40 |
Changing viewfactor Model and use the changed my model by calling "mySolver" | FabianF | OpenFOAM Programming & Development | 2 | January 14, 2014 11:25 |
