createBaffles "You might have to edit these fields." |
September 5, 2023, 10:51 |
Huang, Ching-Chan
Rep Power: 3 |
I want to used createBaffles -overwrite, but it show this
$ createBaffles –overwrite Using: OpenFOAM-2212 (2212) - visit www.openfoam.com Build: _f8e05934-20230403 (patch=230110) Expected 0 arguments but found 1 See 'createBaffles -help' for usage or 'createBaffles -help-full' for extended usage then i use only createBaffles it show Code:
$ createBaffles /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _f8e05934-20230403 OPENFOAM=2212 patch=230110 version=2212 Arch : "LSB;label=32;scalar=64" Exec : createBaffles Date : Sep 05 2023 Time : 21:29:28 Host : ailab05 PID : 237085 I/O : uncollated Case : /home/ailab-05/flapping_wing/rotation/2_parallel nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&, Foam::IOstreamOption::compressionType) in file db/IOstreams/IOstreams/IOstreamOption.C at line 115 Unknown compression specifier 'uncompressed', using compression off Create mesh for time = 0 Reading baffle criteria from createBafflesDict Not converting faces on non-coupled patches. Reading geometric fields Reading volScalarField: p Reading volVectorField: U Created zone rotating at index 1 with 86220 faces Converted 2664 faces into boundary faces in patches 2(AMI1 AMI2) --> FOAM Warning : From int main(int, char**) in file createBaffles.C at line 868 Setting field on boundary faces to zero. You might have to edit these fields. Writing mesh to 0.01 End how can i solve it here is my createBafflesDict code Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object createBafflesDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Whether to convert internal faces only (so leave boundary faces intact). // This is only relevant if your face selection type can pick up boundary // faces. internalFacesOnly true; // Baffles to create. baffles { rotating { //- Use predefined faceZone to select faces and orientation. type faceZone; zoneName face_inner_volume; //zoneName cell_inner_volume; //zoneName inner_volume; patches { master { //- Master side patch name AMI1; type cyclicAMI; matchTolerance 0.0001; neighbourPatch AMI2; transform noOrdering; //OF7 < //transform none; //OF8 and up } slave { //- Slave side patch name AMI2; type cyclicAMI; matchTolerance 0.0001; neighbourPatch AMI1; transform noOrdering; //OF7 < //transform none; //OF8 and up } } } } // ************************************************************************* // |
September 6, 2023, 05:26 |
Rep Power: 5 |
Hey
I can't help you about the overwrite option not working, but the warning about editing the fields just means that in the new time folder created and containing the new mesh, OpenFOAM usually tries to create the boundary files updated with the new baffles you juste created. OF warns you that you should check those files just in case it messed up something. So it does not mean that something went wrong, just double check the new files and you should be good! |
createbafflesdict, opeanfoam |
[mesh manipulation] What does "Reading volScalarField: cellLevel" mean during createBaffles? | Florian Mlehliw | OpenFOAM Meshing & Mesh Conversion | 1 | August 12, 2023 10:05 |
Problem with createBaffles - want to make master and slave internal patches | artymk4 | OpenFOAM | 1 | May 22, 2021 06:45 |
CreateBaffles on open/closed models | wouterremmerie | OpenFOAM Post-Processing | 1 | June 18, 2018 06:38 |
[Commercial meshers] createBaffles for fluent3DMeshToFoam | cfdonline2mohsen | OpenFOAM Meshing & Mesh Conversion | 2 | August 14, 2015 06:02 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
