July 21, 2023, 08:40 |
A problem about blockMeshDict
Rep Power: 4 |
Hello, Foamers!
I have a problem about the function "project" in blockMeshDict file. This blockMeshDict file is in a case about NACA0012(you can find it easily). The code is Code:
project ($aerofoil.xLower -0.1 $domain.zMin) (cylinder) // 0 (0.3 -0.1 -2) project ($aerofoil.xLead -0.1 $aerofoil.zLead) (aerofoil) // 4 (0 -0.1 0) project ($aerofoil.xTrail -0.1 $aerofoil.zTrail) (aerofoil)// 5 (1 -0.1 0) Is the function 'project' a mapping? What the relationship between the points "($aerofoil.xLower -0.1 $domain.zMin)" and cylinder(cylinder is a geometry)? How does the 'project' function work? I welcome any answer, and I believe the more discussed the question, the clearer it becomes. |
October 27, 2023, 09:47 |
Lorenzo
Rep Power: 6 |
I think "project" is projecting or mapping the vertex onto the surface indicated (cylinder or aerofoil), which has been loaded before. It should be referring to the source file you can find in the following link: https://www.openfoam.com/documentati...8H_source.html Other useful files are located in: FOAM_SRC/mesh/blockMesh Regards, Lorenzo |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 19:41 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
