Variation of boundary condition using codedFixedValue
Old   June 15, 2023, 09:14
Default Variation of boundary condition using codedFixedValue
Clément Pélissier
clempel is on a distinguished road
I am on a project on which one I want build a variation of the boundary condition of the slope. For this, I use codedFixedValue and want to retrieve the time of the simulation and the endtime of the simulation as a scalar as it runs. But I can't find the good function or syntaxe to retrieve these both values. I work on OpenFOAM 9.
Here is the code to let you understand what I want to explain.
I hope that someone can help me.
Thank you very much in advance,
Clément
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       volScalarField;
    location    "0";
    object      T;
dimensions      [ 0 0 0 1 0 0 0 ];
internalField   uniform 296.15;
boundaryField
    ground
        type            fixedValue;
        value           uniform 296.15;
    slope
    type            codedFixedValue;
    value           uniform 0;  // initial value
    name            variationHeatFlux;
    code
        #include "createTime.H"
        #include "Time.H"
        const fvPatch& patch = this->patch();
        const vectorField& cf = patch.Cf();
        scalarField& field = *this;
        forAll(cf, i)
            const scalar currentTime = runTime.time();  // current time of the simulation
            const scalar endTime = runTime.endtime();  // end of the simulation
            const scalar tStart = 0;         // initial time
            const scalar gradStart = 0;    // initial gradient
            const scalar gradMax = 758.99;     // maximal gradient
            const scalar tMax = endTime/2;         // maximal gradient time (half of the simulation)
            const scalar gradDecrease = gradMax/tMax;  // decrease step after reach maximum
            scalar grad;
            if (currentTime <= tMax)
                grad = gradStart + (gradMax - gradStart) * (currentTime - tStart) / (tMax - tStart);
            else
                grad = gradMax - gradDecrease * (currentTime - tMax) / (endTime - tMax);
            field[i] = grad;
    ceiling
        type            fixedValue;
    front
        type            symmetryPlane;
    back //maybe here we need to use frontandback with zerogradient
        type            fixedValue;
    right //maybe here we need to use sideWalls with zerogradient
        type            cyclic;
    left
        type            cyclic;
clempel is offline   Reply With Quote
Old   July 5, 2023, 03:45
CFDUser29 is on a distinguished road
I am new to openfoam, but if you set a good writing step in controlDict, shouldn't it be enough ?
I notice that you might forgot a "const" before "scalar grad".
CFDUser29 is offline   Reply With Quote
Old   July 7, 2023, 03:56
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
You mostly have the right idea except for the fatal mistake of using 'include "createTime.H"' within your code. This is definitely not what you want!
It goes off and tries to create TIme by reading the system/controlDict (every time that you call the boundary condition). It also means that that particular Time you have created corresponds to the time state at the start of the simulation.
What you do want is to go from the *this (the boundary condition) back upwards, for example:
// Starting from the fvPatchField (*this)
const Time& runTIme = this->db().time();
https://www.openfoam.com/documentati...atchField.html
Oh, and it would be cleaner to grab the current/end times outside of the loop! If you rework the code you'll see that it reduces down to a single value, which you can then assign to the entire field in one step.
olesen is offline   Reply With Quote
codedfixedvalue, openfoam9, runtime
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
