How to run the case with #codeStream to generate the initial condition in fe41 |
young4of
Rep Power: 4 ![]() |
Hi everyone!
Recently I was using codeStream to generate the initial conditions I wanted, but after using solids4foam &>log, I got the following result, where the log file ends with the is up to date. The detail is as follow. _97f89ca9e8c9e14ee938b417e0c5322af4cd6fc2/../platforms/linux64GccDPInt32Opt/lib/libcodeStream_97f89ca9e8c9e14ee938b417e0c5322af4cd 6fc2.so' is up to date. And the terminal shows segmentation fault (core dumped). I really want to know the operation flow of using codestream in foam-extend4.1. Is there any difference between it and other versions? What I use is that blockMesh first and then the solver solid4Foam & > log directly. But it doesn't seem to make computing work. Really hope you could give me some suggestions. Thanks ! Young |
Philip Cardiff
Rep Power: 34 ![]() ![]() |
Hi Young,
Does codeStream work in foam-extend-4.1 with other solvers? I do not have experience with it. If it works with other solvers, then it should work with solids4foam. |
young4of
Hi Philip,
Hmmm, it seems not. I have tried with icoFoam, but the same thing happened. My whole process is the same as many video tutorials, though they don't use the extend version. Maybe it is the key point. So I'm curious about what to do in the extend version. Anyway, thank you! Young |
codestream, foam-extend 4.1, solids4foam |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
