Setting up of denseParticleFoam
Old   June 13, 2023, 08:00
Default Setting up of denseParticleFoam
Jose paul b
josepaulb is on a distinguished road
Hello
I am currently validating a study on sediment transport problem in openfoam 10.I have used MPPICCloud in cloud properties.
This is the error i am receiving while running in denseParticleFoam as a trial.The geometry is cuboid with inlet,outlet,bed(wall) and symmetry boundaries.
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: No corrector convergence criteria found
        Calculations will do 2 corrections
PIMPLE: Operating solver in transient mode with 2 outer correctors
Reading g
Reading field U
Reading field p
Reading/calculating continuous-phase face flux field phic
Creating turbulence model
Selecting viscosity model Newtonian
Creating field alphac
Constructing clouds
Selecting parcelCloud MPPICCloud
Constructing particle forces
    Selecting particle force sphereDrag
    Selecting particle force gravity
Constructing cloud functions
    none
Constructing particle injection models
Creating injector: model1
Selecting injection model patchFlowRateInjection
    Constructing 3-D injection
    Choosing nParticle to be a fixed value, massTotal variable now does not determine anything.
Selecting distribution model fixedValue
    Distribution min: 0.00017 max: 0.00017 mean: 0.00017
Selecting dispersion model none
Selecting patch interaction model localInteraction
    Interaction fields will not be written
Selecting stochastic collision model none
Selecting surface film model none
Selecting U integration scheme Euler
Selecting packing model implicit
Selecting particle stress model HarrisCrighton
Selecting damping model none
Selecting isotropy model stochastic
Selecting time scale model isotropic
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
RAS
    RASModel        kOmegaSST;
    turbulence      on;
    printCoeffs     on;
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555555555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
No fvModels present
No fvConstraints present
Starting time loop
Courant Number mean: 2.58125000001e-05 max: 0.00413
deltaT = 0.000119904076739
Time = 0.000119904s
Solving 3-D cloud cloud
--> FOAM FATAL ERROR:
    request for surfaceScalarField phi from objectRegistry region0 failed
    available objects of type surfaceScalarField are
3
phi.water
alphaPhi.water
alphacf
    From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-10/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 211.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >(Foam::word const&) const in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/denseParticleFoam"
#3  Foam::PatchFlowRateInjection<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > >::flowRate() const at ??:?
#4  Foam::PatchFlowRateInjection<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > >::parcelsToInject(double, double) at ??:?
#5  void Foam::InjectionModel<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > >::inject<Foam::MPPICCloud<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > > >(Foam::MPPICCloud<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > >&, Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> >::trackingData&) at ??:?
#6  void Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > >::evolveCloud<Foam::MPPICCloud<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > > >(Foam::MPPICCloud<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > >&, Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> >::trackingData&) at ??:?
#7  void Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > >::solve<Foam::MPPICCloud<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > > >(Foam::MPPICCloud<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > >&, Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> >::trackingData&) at ??:?
#8  virtual thunk to Foam::ParcelCloud<Foam::MPPICCloud<Foam::MomentumCloud<Foam::ParcelCloudBase<Foam::MPPICParcel<Foam::MomentumParcel<Foam::particle> > > > > >::evolve() at ??:?
#9  Foam::parcelCloudList::evolve() at ??:?
#10  ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/denseParticleFoam"
#11  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#12  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13  ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/denseParticleFoam"
Aborted (core dumped)
I searched for previous posts regarding same problem and tried to change according to the recommendations.
I don't where else should I define phi.But still I am getting the error.
These are the boundary conditions used.I am combining into a single code block.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  10
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       volScalarField;
    object      k.water;
dimensions      [0 2 -2 0 0 0 0];
// value computed for a turbulence intensity = 5 %    -    0.24
internalField   uniform 0.00063963375;
boundaryField
    side_1
     type symmetry;
   //  phi     phi.water;
    side_2
      type symmetry;
     // phi     phi.water;
    Top
      type symmetry;
    //  phi     phi.water;
    Bottom
      type kqRWallFunction;
    Inlet
      type fixedValue;
      value uniform 0.00063963375;
    //        phi phi.water;
    Outlet
       type            inletOutlet;
    phi             phi.water;
        inletValue      $internalField;
        value           $internalField;
     \\/     M anipulation  |
FoamFile
    format      ascii;
    object      nut.water;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
side_1
     type symmetry;
    side_2
     type symmetry;
    Top
     type symmetry;
    Bottom
     type nutkRoughWallFunction;
     value uniform 0;
     Ks uniform 425e-6;
     Cs  uniform 0.5;
    Inlet
     type   fixedValue;
     value  uniform 0;
    Outlet
      type zeroGradient;
    //  phi phi.water;
     \\/     M anipulation  |
FoamFile
    format      ascii;
    object      omega.water;
dimensions      [0 2 -3 0 0 0 0];
//value computed for a turbulence intensity = 5%     -    345
internalField   uniform 18.46992149415;
boundaryField
   side_1
     type symmetry;
    side_2
      type symmetry;
    Top
      type symmetry;
    Bottom
      type omegaWallFunction;
    Inlet
      type fixedValue;
      value uniform 18.46992149415;
    Outlet
     type            inletOutlet;
    phi             phi.water;
     \\/     M anipulation  |
FoamFile
    format      ascii;
    object      p;
boundaryField
    side_1
         type symmetry;
    //  phi     phi.water;
    side_2
         type symmetry;
   //   phi     phi.water;
    Top
     type symmetry;
     // phi     phi.water;
    Bottom
    type fixedFluxPressure;
//      phi     phi.water;
    Inlet
    type totalPressure;
    p0 uniform 88.76115825;
    value uniform 88.76115825;
  //  phi phi.water;
    Outlet
        gradient        uniform 0;
        value           uniform 0;
        phi phi.water;
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       volVectorField;
    object      U.water;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    side_1
         type symmetry;
   //   phi     phi.water;
    side_2
         type symmetry;
   //            phi     phi.water;
    Top
     type symmetry;
  //    phi     phi.water;
    Bottom
     type noSlip;
//      phi     phi.water;
    Inlet
      type            fixedValue;
        value           uniform (0 0.413 0);
    Outlet
     type            pressureInletOutletVelocity;
        inletValue      uniform (0 0 0);
        value           uniform (0 0 0);
     phi phi.water;
Could someone give any suggestions for the change I should make?Any suggestions are fine.
josepaulb is offline   Reply With Quote
Old   November 8, 2023, 10:30
Default a possible solution
Fotis Anagnostopoulos
efalpha is on a distinguished road
It is a bit late, however i post my solution just in case. I had the same problem and i solved it via setting "phi phi.x;" where x is a placeholder for the name of your phase.
However, I see that you have a similar line per patch commented out. Did you try it?
efalpha is offline   Reply With Quote
openfoam, sediment transport
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 07:08
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Warning 097- AB Siemens 6 November 15, 2004 05:41
