Salome meshing viscous layer thickness not reached
Old   May 11, 2023, 04:25
Default Salome meshing viscous layer thickness not reached
Jaka Baš
BasJaka is on a distinguished road
Hi, I am having a bit of a problem with adding a viscous layer in Salome for my particular problem.
I am trying to mesh a grid, a bunch of paralel and perpendicular thin strips of metal. Salome has no problems meshing the geometry withouth viscous layers. However, when I try to add viscous layer to walls of these strips Salome makes correct number of layers but not the correct thickness of the whole viscous mesh. It exits with error "viscous layers thickness not reached, average thickness ..." (some small value). It doesn't mesh the rest of the geometry, there are only volumes in the thin viscous layer that it created.
I believe it has to do with the geometry. Maybe the problem is the thickness of the strips? Does anyone have any ideas how to succesfully mesh such a grid?
(I added .hdf file in attachment)
Thanks in advance!
BasJaka is offline   Reply With Quote
[snappyHexMesh] Prism layer collapsing in refinement transition rubenparedes OpenFOAM Meshing & Mesh Conversion 8 May 13, 2021 11:55
[snappyHexMesh] Holes in internal mesh when adding boundary layer snappyHex otaolafr OpenFOAM Meshing & Mesh Conversion 3 February 8, 2021 09:19
Boundary Layer and First Layer Thickness mazhar16823 Main CFD Forum 3 April 8, 2020 17:04
[snappyHexMesh] Meshing a very thin meatus with SnappyHexMesh enginpower OpenFOAM Meshing & Mesh Conversion 29 September 9, 2017 04:46
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
