Overset region inside another overset region
Old   March 14, 2023, 06:22
Default Overset region inside another overset region
kompe is on a distinguished road
Good day.
I'm trying to figure out how to do a simulation where I need one overset region inside another one. The flow problem that motivates this is a 2D simulation of a vertical axis wind turbine with three blades. The blades are rotating around a common centre (the first overset region), but each blade are also changing their pitch angles as they move around (the second, and also third and fourth overset regions). Before I get to that though I have to be able to do a more simple model with one overset region inside another one, and from that I think I should be able to build the other one.
I'm able to do simulations with one overset region, but I struggle with the formulation and hierarchy of topoSet and setFields etc. when I have two overset regions where one is dependent of the other's motion. I haven't been able to find anyone else doing this, but I'm sure I can't be the first to have the need.
Any help and pointers in the right direction would be highly appreciated.
kompe is offline   Reply With Quote
Error when solving p_rgh bob94 OpenFOAM 0 March 17, 2020 09:12
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Temperature condition inside an entire region Twinsen_cfd STAR-CCM+ 2 November 20, 2014 04:36
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
