applyBoundaryLayer for LES Pipe Flow simulation 1/7th power law with recycle plane
Old   February 24, 2023, 14:00
Question applyBoundaryLayer for LES Pipe Flow simulation 1/7th power law with recycle plane
JM27 is on a distinguished road
I am setting up a turbulent pipe flow simulation using LES with the WALE SGS model. I would like to set the inlet velocity profile as a 1/7th power law and have come across the applyBoundaryLayer utility.
I have searched the tutorials and this forum and there do not seem to be any examples illustrating the functionality of applyBoundaryLayer.
I currently run blockMesh followed by applyBoundaryLayer -ybl <value>. However this does not seem to be making any changes to the inlet velocity profile.
The applyBoundaryLayer utiility also requires the specification of a wallDist which I have included at the end of the fvSchemes dictionary. I am using meshWave. Am I missing something here?
Alternatively, is the only other way to specify an inlet velocity profile 1/7th power law by using groovyBC/swak4Foam?
Any help will be greatly appreciated.
JM27 is offline   Reply With Quote
Old   April 14, 2023, 13:35
Default 1/7th power law profile does not go to zero at walls - applyBoundaryLayer
I have made same progress with this. The issue was that the internalField was set to (0 0 0) which was a rookie mistake as applyBoundaryLayer is based on the values of the internalField.
However, I am now struggling to understand why the value of velocity does not go to zero at the walls, as one would expect. Can some provide an explanation for this?
applyboundarylayer, les, pipeflow, recycled inflow, walldist
what's the error in fluent pipe flow simulation manupanand FLUENT 1 November 30, 2022 06:30
Turbulent flow simulation in a long pipe ammarali311 FLUENT 3 June 5, 2020 15:39
FDTD Simulation of flow through tapered pipe Jim Main CFD Forum 3 December 25, 2006 11:56
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
