fix the field/unlimit gas source
Old   February 9, 2023, 06:43
Default fix the field/unlimit gas source
Huang, Ching-Chan
Allen_Huang is on a distinguished road
I want to set the unlimit enthanol vapor soure at setFields area. Using the scalarTransportFoam to simulate the diffusion of ethanol vapor. What should i do so i can set the unlimit field(fixed value)/constant concentration? fv0ption?
Allen_Huang is offline   Reply With Quote
boundary condition, fixedvalue, fv0ption
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
