fvOptions: setting heat source
Old   November 30, 2022, 12:04
Default fvOptions: setting heat source
Tsubasa1995 is on a distinguished road
Hello all,
I am new to Openfoam.
I am trying to set a heat source in a solid domain.
In my case, the mesh is exported from Salome, and a certain solid region is named "source" for the heat source in Salome. By "ideasUnvToFoam", the mesh is converted now. Looking at the polyMesh/cellZones, I can see
source
type cellZone;
cellLabels List<label>
30
21
26
27
28
34
44
53
56
70
73
75
81
82
87
88
89
94
95
96
102
103
110
121
127
160
163
168
177
178
182
So now I want to use this "source" as a heat sourc. I am using "scalarTransportFoam" for the simulaiton.
At the moment, I use this fvOption file
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object fvOptions;
heatSource
type scalarSemiImplicitSource;
active true;
selectionMode cellZone;
scalarSemiImplicitSourceCoeffs
// selectionMode cellZone; // all, cellSet, cellZone, points
cellSet source;
volumeMode absolute; // absolute, specific
injectionRateSuSp
T (1 0);
but the terminal said
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 10
\\/ M anipulation |
Build : 10-0347120b3b9d
Exec : scalarTransportFoam
Date : Nov 30 2022
Time : 15:24:20
Host : "tsubasa-VirtualBox"
PID : 15991
I/O : uncollated
Case : /home/tsubasa/デスクトップ/paris8_test
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: No convergence criteria found
Reading field T
Reading field U
Reading physicalProperties
Reading diffusivity DT
--> FOAM Warning : Creating fvModels from "constant/fvOptions"
Selecting finite volume model type scalarSemiImplicitSource
--> FOAM FATAL IO ERROR:
Unknown fvModel scalarSemiImplicitSource
Valid fvModels are:
22
accelerationSource
actuationDiskSource
buoyancyEnergy
buoyancyForce
coded
effectivenessHeatExchangerSource
explicitPorositySource
heatSource
heatTransfer
interRegionExplicitPorositySource
interRegionHeatTransfer
isotropicDamping
massSource
phaseLimitStabilisation
radialActuationDiskSource
rotorDisk
semiImplicitSource
sixDoFAccelerationSource
solidEquilibriumEnergySource
solidificationMeltingSource
verticalDamping
volumeFractionSource
file: /home/tsubasa/デスクトップ/paris8_test/constant/fvOptions/heatSource from line 20 to line 31.
From function static Foam::autoPtr<Foam::fvModel> Foam::fvModel::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
in file cfdTools/general/fvModels/fvModel.C at line 117.
FOAM exiting
What is wrong now? Because I am not familiar with Openfoam enough, could someone help me?
Best regards,
Tsubasa
Tsubasa1995 is offline   Reply With Quote
Old   December 1, 2022, 09:07
Default Next error
I solved the problem above, but I face a new problem.
Would someone help me?
fvOption
*--------------------------------*- C++ -*----------------------------------*\
| \\ / O peration | Version: dev |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvOptions;
source_setting
type heatSource;
cellZone sourcesourcesource;
Q 1;
Error masage
\\/ M anipulation |
Date : Nov 30 2022
Time : 22:51:00
PID : 18414
I/O : uncollated
nProcs : 1
Create time
Reading field T
Reading field U
Selecting finite volume model type heatSource
- selecting cells using cellZone sourcesourcesource
- selected 30 cell(s) with volume 0.04
--> FOAM Warning : Creating fvConstraints from "constant/fvOptions" rather than system/fvConstraints
No fvConstraints present
Calculating scalar transport
Courant Number mean: 1.46639 max: 4.77925
Time = 0.1s
--> FOAM FATAL ERROR:
lookup of physicalProperties from objectRegistry region0 successful
but it is not a basicThermo, it is a dictionary
From function const Type& Foam:bjectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::basicThermo]
in file /home/ubuntu/OpenFOAM/OpenFOAM-10/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 178.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::basicThermo const& Foam:bjectRegistry::lookupObject<Foam::basicTher mo>(Foam::word const&) const at ??:?
#3 Foam::fv::heatSource::addSupFields() const at ??:?
#4 Foam::fvModel::addsSupToField(Foam::word const&) const at ??:?
#5 Foam::tmp<Foam::fvMatrix<double> > Foam::fvModels::source<double>(Foam::GeometricFiel d<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&, Foam::dimensionSet const&) const in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/scalarTransportFoam"
#6 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/scalarTransportFoam"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/scalarTransportFoam"
中止 (コアダンプ)
fvoptions heat source
Adding temperature dependent heat source using fvOptions in chtMultiRegionSimpleFoam shaileshbg OpenFOAM Running, Solving & CFD 14 January 26, 2024 19:48
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
