November 29, 2022, 20:39 |
Cyclic BC for a twisted hexagonal cylinder
Yicong
Hi guys,
I have created an O-grid for a twisted hexagonal cylinder in Pointwise v18.5 and exported the mesh as a polyMesh folder into openfoam-v2112 (the .com version). cylinder_spanwise.PNG cylinder.PNG O-grid.PNG When I try and make the z-axis spanwise endwalls cyclic, I get the following error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _14aeaf8dab-20211220 OPENFOAM=2112 version=v2112 Arch : "LSB;label=32;scalar=64" Exec : checkMesh Date : Nov 30 2022 Time : 00:17:56 Host : PID : I/O : uncollated Case : nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 --> FOAM FATAL ERROR: (openfoam-2112) face 647 area does not match neighbour by 0.013587605% -- possible face ordering problem. patch:back my area:0.00030710446 neighbour area:0.00030714619 matching tolerance:0.0001 Mesh face:13372775 fc:(-0.061516008 0.38151984 -0.12566371) Neighbour fc:(-0.061516383 -0.3815217 -1.5549985e-11) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From void Foam::cyclicPolyPatch::calcTransforms(const primitivePatch&, const pointField&, const vectorField&, const pointField&, const vectorField&) in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 215. FOAM exiting Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _14aeaf8dab-20211220 OPENFOAM=2112 version=v2112 Arch : "LSB;label=32;scalar=64" Exec : checkMesh Date : Nov 30 2022 Time : 01:19:14 Host : PID : I/O : uncollated Case : nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Time = 0 Mesh stats points: 4543992 faces: 13501728 internal faces: 13372128 cells: 4478976 faces per cell: 6 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 4478976 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology front 23328 23544 ok (non-closed singly connected) cylinder 41472 41688 ok (non-closed singly connected) back 23328 23544 ok (non-closed singly connected) inlet 20736 21037 ok (non-closed singly connected) outlet 20736 21037 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking geometry... Overall domain bounding box (-0.4 -0.4 -0.12566371) (0.4 0.4 2.5839636e-10) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (8.5138466e-17 7.1580333e-18 -3.4146196e-15) OK. Max cell openness = 6.4200843e-16 OK. Max aspect ratio = 41.659087 OK. Minimum face area = 2.466335e-09. Maximum face area = 0.00031118574. Face area magnitudes OK. Min volume = 1.618582e-12. Max volume = 2.0366275e-07. Total volume = 0.063112991. Cell volumes OK. Mesh non-orthogonality Max: 53.984103 average: 10.653729 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.5850591 OK. **Error in coupled point location: 14398 faces have their 0th or consecutive vertex not opposite their coupled equivalent. Average mismatch 0.00099244962. <<Writing 14398 faces with incorrectly matched 0th (or consecutive) vertex to set coupledFaces Failed 1 mesh checks. End Code:
--> FOAM FATAL ERROR: (openfoam-2112) Unable to set target face for source face 15178 From virtual bool Foam::faceAreaWeightAMI::setNextFaces(Foam::label&, Foam::label&, Foam::label&, const Foam::bitSet&, Foam::labelList&, const Foam::DynamicList<int>&, bool) const in file AMIInterpolation/AMIInterpolation/faceAreaWeightAMI/faceAreaWeightAMI.C at line 363. FOAM aborting case file The mesh is very fine, so I am running the case in parallel, but I haven't included this in the case file link, since I don't think this is affecting the cyclic BC issue. Thanks! |
December 26, 2022, 12:10 |
Rep Power: 6 |
General question, did you use a createPatchDict and the createPatch command, to set up the polyMesh/boundary file correctly? because i couldnīt find the dict in your case files.
cyclic bc, twisted geometry |
Flow pass 2D square cylinder using LES-channel 395 question | Bashar | OpenFOAM | 1 | January 8, 2021 01:53 |
How to implement time-varying boundary conditions in an enclosed cylinder | Alejandro-FA | OpenFOAM Pre-Processing | 0 | May 14, 2020 06:29 |
cyclic BC, cylinder array | el_nando_97 | OpenFOAM Running, Solving & CFD | 1 | February 25, 2020 02:34 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
