correctors due to the mesh description
Old   September 15, 2022, 10:20
Post correctors due to the mesh description
cal
saidc. is on a distinguished road
I've a really complex geometry and I can't create better mesh than I've already done. Because of this I need to force the foam to get accurate results but it diverges with high nNonOrthogonalCorrectors. I calculated 0.25, 0.5, 0.75, 0.99, 0.999, 0.9999 quantiles of mesh data to describe it as much as possible. I believe 0.9999 is the one that carrying more information. The simulation is laminar, closed natural convection case. All boundries are wall and has adiabatic bc. Solver is buoyantPimpleFoam.
I want to know your ideas how you would set the fvSolution and fvSchemes for this mesh. I attached meshDescription.png, please check it.
solvers
    "rho.*"
    solver             PCG;
    preconditioner  DIC;
    tolerance         0;
    relTol              0;
    p_rgh
        solver             GAMG;
        tolerance        1e-06;
        relTol              0.01;
        smoother         GaussSeidel;
    p_rghFinal
        solver             GAMG;
        tolerance        1e-07;
        relTol              0.0;
    "(U|h)"
        solver             PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol             0.0;
    "(U|h)Final"
        $U;
        tolerance       1e-08;
        relTol             0.0;
PIMPLE
    momentumPredictor no;
    nNonOrthogonalCorrectors 2;
    nOuterCorrectors 1;
    nCorrectors         3;
    pRefCell              0;
    pRefValue           1e5;
ddtSchemes
    default         Euler;
gradSchemes
    default          Gauss linear;
    grad(U)         cellLimited Gauss linear 0.75;
divSchemes
    default          none;
    div(phi,U)       Gauss linearUpwind grad(U);
    div(phi,h)       Gauss upwind;
    div(phi,K)         Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default          Gauss linear limited 0.75;
interpolationSchemes
    default          linear;
snGradSchemes
    default          limited 0.75;
saidc. is offline   Reply With Quote
accuracy, mesh, nonorthofaces
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces Hamid.de Pointwise & Gridgen 4 November 9, 2016 12:20
Fatal overflow error, singularity, due to local mesh form? Thomasbr CFX 7 July 8, 2016 10:57
error message cuteapathy CFX 14 March 20, 2012 07:45
