August 30, 2022, 09:22 |
interFoam error while running
Rep Power: 4 |
I new to OpenFOAM and tried to solve my first case.
With a lot of help in the forum here and on youtube i came pretty far. However now i get something that i even not know where to look for the solution. The model is based on the waterchannel tutorial. I will include here the end of the dump as the rest starts up normally: Reading hRef Calculating field g.h Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { model kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present No fvModels present No fvConstraints present #0 Foam::error:: printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::adjustPhi(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) at ??:? #4 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/interFoam" #5 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/interFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/interFoam" Floating point exception (core dumped) Any clue where i need to look? Regards, Tinus |
September 3, 2022, 05:06 |
#2 | |
Al
Rep Power: 7 |
Additionally, it's important to keep in mind that this tutorial includes an Allrun.pre file so it is required to use the Allrun script to run this tutorial. Best, |
Running InterFoam with dynamic mesh | Abhinav Dixit | OpenFOAM Running, Solving & CFD | 1 | June 30, 2022 20:21 |
interFoam error while running | Legacy | OpenFOAM Running, Solving & CFD | 0 | May 23, 2022 13:23 |
interFoam running blowing up | sandy13 | OpenFOAM Running, Solving & CFD | 2 | May 5, 2015 07:16 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
InterFoam / InterDyFoam running problem | anon_c | OpenFOAM Running, Solving & CFD | 1 | August 26, 2009 03:54 |
