How to define blocks in blockmesh
Old   August 14, 2022, 15:01
Default How to define blocks in blockmesh
Thiago800 is on a distinguished road
I am trying to make a big block out of nine smaller blocks to be able to refine them separately afterwards.
I defined the vertices and the blocks, as you can see below. I tried to define it in a few ways, but none of them worked. Every time when I run the blockMesh command, there are some mistakes.
Could someone please help me find out what's wrong?
The blockMeshDict file and a picture which shows the mistake is included.
Thanks in advance
Thiago800 is offline   Reply With Quote
Old   August 15, 2022, 08:25
Domenico Lahaye
dlahaye is on a distinguished road
Does this https://github.com/damogranlabs/classy_blocks help?
dlahaye is offline   Reply With Quote
Old   August 16, 2022, 10:56
Hi dlahaye, thanks for your response. I don't have any experience with python therefor unfortunately it's not helpful. Is there maybe a simpler tool or way to do that?
blockmesh
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 22:13
[blockMesh] blockMesh problem with wedge blocks gned OpenFOAM Meshing & Mesh Conversion 0 September 14, 2016 06:49
[blockMesh] How to define symmetric graded mesh without using multiple blocks sahmed OpenFOAM Meshing & Mesh Conversion 3 August 18, 2016 04:33
An odd ERROR mdakbari Fluent UDF and Scheme Programming 7 April 4, 2016 05:30
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
