Pressure high between two patches in normal pipe flow
Old   July 27, 2022, 11:25
Default Pressure high between two patches in normal pipe flow
shouvik ghorui
shouvik ghorui is on a distinguished road
I am working in normal flow through the pipe for that. I am meshing it in snappyHexMesh. the checkMesh is showing that mesh is okay. But after solving it in pimpleFoam it shows a pressure discontinuity around the junction of two patches( lobe and wall).
Total 3 patches :
1. inlet
2. body(wall)
3. lobe(outlet)
pressure: inlet---> fixedValue 0 ; body ----> zeroGradient ; lobe ---> zeroGradient;
Velocity: inlet---> zeroGradient ; body ----> noSlip; lobe ---> fixedValue (0 0 0.001024);
Here I am attaching snappyHexMesh, pressure contour, and case file.snappy.png
https://drive.google.com/file/d/1UzC...ew?usp=sharing
can anyone suggest what I should do to solve this pressure issue?
Thanks .
Note: when I am using Ansys meshing, this problem gets solved.
I noticed This pressure discontinuity is happening between two zeroGradient pressure BC.
shouvik ghorui is offline   Reply With Quote
pressre distribution, pressure b.c, snappyhexmesh 3d
High negative pressure in incompressible flow simulation user_HH OpenFOAM Programming & Development 0 February 4, 2021 15:40
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Modeling flow in a high pressure piston pump mazdak Main CFD Forum 4 April 24, 2019 14:17
Initial pressure in water pipe flow mhmmdali FLUENT 10 March 18, 2019 04:09
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
