Time-varying step function boundary condition
Old   July 20, 2022, 04:36
Default Time-varying step function boundary condition
Giulia
letoppina is on a distinguished road
Is there a way to impose a squared (or trapezoidal) velocity profile (on the boundary condition of my fluid) instead of a simple sinusoidal shape?
I am using OpenFOAM version 6 and chtmultiregionfoam solver.
Thank you
letoppina is offline   Reply With Quote
Old   July 21, 2022, 10:06
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Thank you
Doesn't exactly fit your question, but openfoam6 is also pretty old. If you pick up something like the newest OpenFOAM-v2206 or OpenFOAM-v2112 etc, they have a pre-defined square wave function that even supports having a different length on vs off period. Other alternatives would be an expression function with your own intervals. If none of these work for you, can also just specify a table of values. It does mean that you essentially need to specify the switching points twice (eg, off until 1.0, on after 1.00001 etc) but could be the path of least resistance for you at the moment.
https://www.openfoam.com/documentati...e.html#details
olesen is offline   Reply With Quote
boundary condition, inlet boundary condition, time-varying b.c., velocity profile
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
