How to specify a tangential velocity for a moving wall? |
July 14, 2022, 14:16 |
De Broglie
Rep Power: 4 |
The title pretty much says it. Imagine we have a physically moving wall, for which the motion is prescribed using pointDisplacement as boundary condition. But we need to also specify an additional tangential wall velocity for which no mesh movement is necessary. How do we go about this?
Thanks a bunch in advance for any help. |
July 14, 2022, 14:33 |
rotatingWallVelocity
Al Csc
Rep Power: 8 |
For ESI-v2206, you find the answer in:
- If rotating, ie cylinder: OpenFOAM-v2206/src/finiteVolume/fields/fvPatchFields/derived/rotatingWallVelocity/rotatingWallVelocityFvPatchVectorField.H Code:
Description This boundary condition provides a rotational velocity condition. Usage \table Property | Description | Required | Default value origin | origin of rotation in Cartesian coordinates | yes| axis | axis of rotation | yes | omega | angular velocty of the frame [rad/s] | yes | \endtable Example of the boundary condition specification: \verbatim // Here what you need: <patchName> // for U { type rotatingWallVelocity; origin (0 0 0); axis (0 0 1); omega 100; } Code:
Description This boundary condition provides a velocity condition for cases with moving walls. Usage Example of the boundary condition specification: \verbatim //What you need: <patchName> // for U { type movingWallVelocity; value uniform (0 0 0); // Initial value } \endverbatim Last edited by al.csc; July 14, 2022 at 14:39. Reason: missing second part |
July 14, 2022, 14:38 |
De Broglie
Rep Power: 4 |
Thank you, al.csc, for replying. But I believe this is a BC that should not be used when the wall is physically moving. Say you have a cylinder that is rotating around its center, then you wouldn't need a mesh movement and could use rotatingWallVelocity safely.
My question relates to when the wall is actually moving. Think a linearly oscillating cylinder that is also rotating at the same time. The oscillation needs mesh movement, whereas the rotation doesn't. |
July 14, 2022, 14:43 |
#4 | |
Al Csc
Rep Power: 8 |
July 14, 2022, 14:45 |
De Broglie
Rep Power: 4 |
Ok, on movingWallVelocity, this BC works well (and should be used) when the wall is physically moving. The problem is that sometimes you don't want the wall to have an actually movement in the tangential direction. In such situations if movingWallVelocity is used, the mesh actually moves in the tangential direction, which is not desirable.
July 14, 2022, 14:50 |
#6 | |
De Broglie
Rep Power: 4 |
No worries, at all. Sometimes you would want to prescribe a specific velocity on the wall in tangential direction, which simulates a wall movement (without the actual movement and hence no need for mesh motion). |
July 14, 2022, 14:55 |
De Broglie
Rep Power: 4 |
Just to add to this, in commercial codes like Fluent or CFX, and when you have dynamic mesh, you could specify a "relative wall velocity" on wall boundaries in addition to wall mesh motion, which would take care of this problem.
dynamic mesh, moving wall, tangential velocity |
Ansys CFD-Post Application Error | rushiCFD | FLUENT | 0 | March 21, 2021 07:51 |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Velocity on a wall is not equal to 0 by LES | starz | FLUENT | 6 | February 23, 2020 15:37 |
Rotating domain vs Wall velocity | Jiricbeng | CFX | 16 | January 30, 2020 09:06 |
