action "delete" in topoSetDict doesn't always work (.org)
Old   June 11, 2022, 22:17
Default action "delete" in topoSetDict doesn't always work (.org)
Michael Jensen
mikethe1wheelnut is on a distinguished road
Here are selected sections of my topoSetDict: (..trying to limit your eye-work..)
#include "$FOAM_CASE/system/blockMeshDict"
actions
name cs;
type cellSet;
action new;
source cylinderToCell;
sourceInfo
point1 (0 0 -100);
point2 (0 0 100);
centre (0 0 0);
radius $cylinderRadiusOuter;
name cs;
type cellSet;
action delete;
sourceInfo
point1 (0 0 -100);
point2 (0 0 100);
centre (0 0 0);
radius $cylinderRadiusInner;
name cs;
type cellSet;
action delete;
source boxToCell;
sourceInfo
box (-10 0 100)(100 100 -100);
name cs;
type cellSet;
action delete;
source boxToCell;
sourceInfo
box (-100 -100 -100)(0 10 1);
name solid;
type cellZoneSet;
action new;
source setToCellZone;
sourceInfo { set cs; }
// ************************************************** *********************** //[/CODE]
I've tried to make it as clear as possible. You will see two places where I delete cells with boxToCell. The second one works, the first one does not. The command-line output:
Reading "topoSetDict"
Time = 0
mesh not changed.
Created cellSet cs
Applying source cylinderToCell
Adding cells with centre within cylinder, with point1 = (0 0 -100), point2 = (0 0 100) and radius = 0.031
cellSet cs now size 269
Read set cellSet cs with size 269
Removing cells with centre within cylinder, with point1 = (0 0 -100), point2 = (0 0 100) and radius = 0.03
cellSet cs now size 22
Read set cellSet cs with size 22
Applying source boxToCell
Removing cells with center within boxes 1((-10 0 100) (100 100 -100))
Removing cells with center within boxes 1((-100 -100 -100) (0 10 1))
cellSet cs now size 13
Created cellZoneSet solid
Applying source setToCellZone
Adding all cells from cellSet cs ...
cellZoneSet solid now size 13
End
[/CODE]
Notice that the cellSet size does not change for the first boxToCell. ..I'd include an image of the result, but it's on my computer, not online. There are cells that should be removed by the first box. ..I can prove this to you, if need be..
mikethe1wheelnut is offline   Reply With Quote
Old   June 12, 2022, 01:46
Default Solved
Michael Jensen
The coordinates of the box must always be lesser -> greater! so, well, exactly as the instructions say, xmin -> xmax, same for y, z.
openfoam 9, toposetdict
Introducing changeDictionaryDict and topoSetDict files in chtMultiRegionFoam fracasce OpenFOAM Pre-Processing 8 October 28, 2015 05:25
First order in fvSchemes does not seem to work gerritgroot OpenFOAM Running, Solving & CFD 0 September 30, 2015 21:06
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 19:00
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Valve action Hrvoje Jasak (Hjasak) OpenFOAM Running, Solving & CFD 0 January 13, 2005 14:23
