Boundary conditions of sinusoidal water motion inside a tube |
May 31, 2022, 05:24 |
Giulia
Rep Power: 4 |
I am trying to simulate a tube (solid region) in which a fluid is flowing inside (fluid region). The fluid enters the tube at the inlet, flows through the tube, reaches the outlet of the tube, and comes back in a sinusoidal fashion. So it means that once the fluid enters the tube, it remains inside and it moves back and forth. It interacts with the tube walls (which are heated) so the fluid will heat up as well and increase its temperature. Given that the fluid has a certain inlet temperature and inlet velocity, how should it be the boundary condition at the outlet? Thank you in advance for your help! |
boundary condition, sinusoidal oscillating, tube fluid, water flow, water injection |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 08:15 |
