Mesh refinement of a Cube
Old   May 17, 2022, 08:09
Default Mesh refinement of a Cube
Thiago800 is on a distinguished road
Hello, I want to refine the mesh of a cube with edge length of 108mm. I am simulating a spray which sprays the fuel from the top to the bottom. I want to refine the mesh on the top where the fuel is injected to the cube. Further down and around the spray, the mesh should be coarser (green block). I want to divide the cube in 9 blocks, as you can see on the attached picture (and inject the fuel unlike on the picture, from the top to the bottom along y axis). The mesh in the middle block should be refined (red block).
I attached the paraview picture to show you from where the injection should begin.
Is it possible to do that by only adjusting simpleGrading or multiGrading? If so, how do I adjust it to achieve this division and refined mesh? I tried it many times, but I don't get it how I want to.
Thank you
Thiago800 is offline   Reply With Quote
mesh refinement study, spray injection
[snappyHexMesh] Sphere tutorial - refined mesh fails nikosb OpenFOAM Meshing & Mesh Conversion 0 March 17, 2022 16:49
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 14:30
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
