can i make a flow source inside the body(stl)?
Old   May 17, 2022, 05:58
Default can i make a flow source inside the body(stl)?
seongju Lee
lsjw41 is on a distinguished road
Hello guys, i'm a totally new beginner of the openFoam.
And english is not my first language so sorry for my grammer.
what i'm trying to do is
1. attaching a flow source(air stream) inside the body
2. studying the effect of flow source on external flow(like a chimney and the atmosphere)
i set the base mesh(external flow) from blockMesh. And i made solid body(stl).
next step is setting the flow source. how can i do this?
making another block in base block(is it possible?)?
thanks
lsjw41 is offline   Reply With Quote
openfoam
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
