Isoflux condition on ChtMultiRegionFoam
Old   April 15, 2022, 02:19
Default Isoflux condition on ChtMultiRegionFoam
Giulia
letoppina is on a distinguished road
Hi, I am trying to simulate a solid body (tube walls) in contact with a fluid (water) with chtMultiRegionFaom solver. The solid walls are able to generate a heat flux (which should be homogeneously distributed within the thickness of the wall), thus giving isoflux conditions on the solid wall in contact with the fluid. This is my boundary condition (T) on my solid wall:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0/toptube";
    object      T;
dimensions      [ 0 0 0 1 0 0 0 ];
internalField   uniform 298.15;
boundaryField
    #includeEtc "caseDicts/setConstraintTypes"
    "maxY"
        type            externalWallHeatFluxTemperature;
        mode            flux;
    heatsource    flux;
        Ta         uniform 298.15;
        q               uniform 100.0; // heat flux [W/m2]
        thicknessLayers (0.0006);  //solid wall thicnkess
        kappaLayers     (0.184);          // thermal conductivity of layer [W/m/K]
        kappaMethod     solidThermo;
        value           $internalField;  // initial temperature [K]
    "(min|max)(X)"
        type            zeroGradient;
       //value           $internalField;
    "(min|max)(Z)"
        type            empty;
        ~value;
    "toptube_to_.*"
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        Tnbr            T;
And this is the boundary condition on the water (in contact with the tube):
FoamFile
    version     2.0;
    format      ascii;
    location    "0/water";
    object      T;
internalField   uniform 288.15;
boundaryField
    minX
        type            fixedValue;
    maxX
        type            inletOutlet;
        inletValue      $internalField;
    "(min|max)(Z)"
        type            empty;
        ~value;
    "water_to_.*"
        Tnbr            T;
        kappaMethod     fluidThermo;
Technically, as the tube is exchanging heat flux with the water, the water should heat up. But on the simulation the heat flux dissipates immediately and the water becomes cold very soon. What am I doing wrong?
letoppina is offline   Reply With Quote
chtmultiregionfoam, flux boundary condition, heat flux., solid body
Access species thermo functions from chtMultiRegionFoam bouandray condition jherb OpenFOAM Programming & Development 2 October 16, 2020 17:52
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 09:33
chtMultiRegionFoam boundary condition dl6tud OpenFOAM Programming & Development 0 March 14, 2014 05:28
Custom boundary condition: unexpected behavior with chtMultiRegionFoam leroyv OpenFOAM Programming & Development 3 February 1, 2014 08:49
conjugate boundary condition Daniel_Khazaei OpenFOAM Programming & Development 0 December 31, 2013 14:11
