setSet: undefined symbol: _ZN4Foam8fileName20allowSpaceInFileNameE
Old   February 14, 2022, 09:51
Unhappy setSet: undefined symbol: _ZN4Foam8fileName20allowSpaceInFileNameE
PatrickP
PatrickP is on a distinguished road
Hello OF users,
I am fresh new to OF and try to run a case for impeller design.
Unfortunately, I run into this problem of setSet as follows:
I am stuck for this that seem not many people encounter this before.
I use Openfoam-dev and spent much time on issue by issue. Frankly, it is not easy to use that I spent more than a month for installation and run and
example case and still cannot succeed.
Hope someone can kindly help!!
Thanks!
Patrick
PatrickP is offline   Reply With Quote
Old   February 18, 2022, 06:31
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by PatrickP View Post
Hello OF users,
Thanks!
Patrick
The allowSpaceInFileName was added into OpenFOAM-v1906 (it really helps the windows users etc), but it sounds like you have mixed up your compilations with a different version of OpenFOAM.
olesen is offline   Reply With Quote
Old   February 23, 2022, 18:43
PatrickP
Do you mean I installed the wrong version of OpenFoam? What should I do to fix this issue?
Old   February 24, 2022, 07:49
Mark Olesen
Which platform are you using, how did you install OpenFOAM? Depending on that, can give some more information. Otherwise take a look at the usual places:
https://www.openfoam.com/news/main-news/openfoam-v2112
https://develop.openfoam.com/Develop...is/precompiled
Old   February 24, 2022, 19:52
PatrickP
A bit complicated and tediously clumsy:
I started by installing OF9(with wsl) according to the instruction of the official website:
https://openfoam.org/download/windows/
When I try to run a tutorial from Youtube: https://www.youtube.com/watch?v=MwgnOdizuG8&t=1743s
I found I was stuck by launching decomposePar. It prompt that I did not install Scotch for parallel processors.
It seems OF9 doesn't include the Scotch. I later installed the Thirdparty based on this:https://openfoam.org/download/9-source/
but still got problem.(I can't remember the error msg.)
Then, I installed the OF-dev version. It gave me the title captured error message.
I later tried OF8 installation but still got problem.
setset
Caffa 3D code Waliur Rahman Main CFD Forum 0 May 29, 2018 01:53
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
