February 9, 2022, 17:02
turbulent flow in a pipe
simona
Hello, I am simulating a turbulent flow in a cylindrical tube using simpleFoam using the k-omega turbulence model, the inlet velocity is fixed at 0.455 m/s, I put below the initial conditions, my fvSolution and fvSchemes file, the solution converges but the maximum velocity I get is equal to 0.605 m/s but it must be 2*0.455 m/s, I tried with a longer tube but it remains the same velocity, can someone tell me the cause of this problem please???
FoamFile
version 2.0;
format ascii;
class volScalarField;
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.00094;
boundaryField
inlet
type fixedValue;
value 0.00094;
outlet
type zeroGradient;
wall
type kqRWallFunction;
value uniform 0.00094;
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
wall
type nutkWallFunction;
value uniform 0;
FoamFile
version 2.0;
format ascii;
object omega;
dimensions [0 0 -1 0 0 0 0];
internalField uniform 72.89;
boundaryField
inlet
type fixedValue;
value 72.89;
outlet
type zeroGradient;
wall
type omegaWallFunction;
value uniform 72.89;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0 0 0.455);
outlet
type zeroGradient;
wall
type noSlip;
FoamFile
version 2.0;
format ascii;
object p;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
wall
type zeroGradient;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.01;
smoother GaussSeidel;
"(U|k|epsilon|omega|f|v2)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-06;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
consistent yes;
residualControl
p 1e-6;
U 1e-6;
"(k|epsilon|omega|f|v2)" 1e-3;
relaxationFactors
equations
U 0.95; // 0.9 is more stable but 0.95 more convergent
".*" 0.95; // 0.9 is more stable but 0.95 more convergent
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwind grad(U);
div(phi,k) bounded Gauss limitedLinear 1;
div(phi,epsilon) bounded Gauss limitedLinear 1;
div(phi,omega) bounded Gauss limitedLinear 1;
div(phi,v2) bounded Gauss limitedLinear 1;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
div(nonlinearStress) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
wallDist
method meshWave;
Reason: wrong title
