February 1, 2022, 14:31 |
mapFields Error
qutadah
Rep Power: 5 |
Hi everyone,
I am getting an error when mapping fields and I am not sure why.... I am trying to map a field from a mesh to another version of the same mesh, that has some recent changes... However I recieve the error and I dont know how to proceed. --> FOAM FATAL ERROR: The distance between the centre of patch INT_BLADE_6-SIDE-1 and the transformed centre of patch INT_BLADE_6-SIDE-2 is 0.08105521. This is greater than the match tolerance of 8.8291549e-06 for the patch. Check that the patches are geometrically similar and that any transformations defined between them are correct It might be possible to fix this problem by increasing the "matchTolerance" setting for this patch in the boundary From function Foam::cyclicTransform::cyclicTransform(const Foam::word &, const Foam::Field<Foam::Vector<double>> &, const Foam::Field<Foam::Vector<double>> &, const Foam::cyclicTransform &, const Foam::word &, const Foam::Field<Foam::Vector<double>> &, const Foam::Field<Foam::Vector<double>> &, const Foam::cyclicTransform &, double) in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicTransform.C at line 474. FOAM exiting Changing the match tolerance is not something I am willing to do, as this I believe is not the correct way to address the issue... I am using OF9 version. Any advice ?! Thanks! |
mapfields, mesh 3d, of9 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
