January 9, 2022, 10:37 |
turbulence field omega stops solver
Christoph
Rep Power: 5 |
Good day all,
I have a problem with running a simulation from results that were mapped onto the mesh. It seems that the omega field stops the solver from starting the time loop. I am using OpenFoam-v1912, i am simulating a rotor blade with SSTLM turbulence model and SRFSimpleFoam. Initially, i have obtained a solution on a coarse mesh and mapped it onto the finer one using mapFieldsPar. This seems to be working fine, all the fields are created and ParaView shows no irregularaties. my procedure: reconstruct initial solution with reconstructPar -latestTimeHowever, when i start the simulation, it stops before the timeloop even starts; producing this log-file (which does not give any information why it stops): Code:
Exec : SRFSimpleFoam -parallel Case : baseCaseMedium nProcs : 8 Hosts : ( (b230 8) ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 1 SIMPLE: convergence criteria field p tolerance 1e-05 field Urel tolerance 1e-06 field k tolerance 1e-06 field omega tolerance 1e-06 field ReThetat tolerance 1e-06 field gammaInt tolerance 1e-06 Reading field p Reading field Urel Reading/calculating face flux field phi AMI: Creating addressing and weights between 59136 source faces and 55552 target faces AMI: Patch source sum(weights) min:0.999998897 max:1.00000001 average:0.999999999 AMI: Patch target sum(weights) min:0.999986073 max:1.00000009 average:0.999999999 Creating SRF model Selecting SRFModel rpm Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSSTLM Selecting patchDistMethod meshWave bounding k, min: 0 max: 16703.522 average: 7.94369825 bounding omega, min: 0 max: 907782106 average: 304329.529 kOmegaSSTLMCoeffs { ... ... } No finite volume options present Edit: the same behaviour occurs when running "in serial" as well. Does anyone have an idea why this is happening? I hope my question is understandable, if any more information is needed please contact me. kind regards Christoph Last edited by woodie; January 10, 2022 at 02:34. |
January 9, 2022, 10:42 |
fvSchemes & fvSolution
Christoph
Rep Power: 5 |
fvSchemes:
HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default cellLimited Gauss linear 1; grad(Urel) cellLimited leastSquares 1; } divSchemes { default none; div(phi,Urel) bounded Gauss linearUpwindV grad(Urel); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div(phi,ReThetat) bounded Gauss upwind; div(phi,gammaInt) bounded Gauss upwind; div((nuEff*dev2(T(grad(Urel))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 0.333; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.333; } wallDist { method meshWave; } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; smoother GaussSeidel; tolerance 1e-7; //change to 10-12; relTol 0.0; //change to 0.0 later minIter 3; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 1000; mergeLevels 1; maxIter 1500; } Urel { solver PBiCGStab; preconditioner DILU; tolerance 1e-8; relTol 0; minIter 2; } "(k|ReThetat|gammaInt)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-7; relTol 0.00; minIter 2; } omega { solver PBiCGStab; preconditioner DILU; tolerance 1e-7; relTol 0.00; minIter 2; } } SIMPLE { nNonOrthogonalCorrectors 3; consistent yes; residualControl { p 1e-5; Urel 1e-6; k 1e-6; omega 1e-6; ReThetat 1e-6; gammaInt 1e-6; } } relaxationFactors { fields { p 0.8; } equations { ".*" 0.75; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object omega; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 -1 0 0 0 0]; internalField uniform 14.3325; boundaryField { BLADE { blended 1; beta1 0.075; type omegaWallFunction; value uniform 14.3325; } INLET { type fixedValue; value uniform 14.3325; } HUB { type zeroGradient; } OUTLET { type inletOutlet; inletValue uniform 14.3325; value uniform 14.3325; } SIDE_LEFT { type cyclicAMI; value uniform 14.3325; } SIDE_RIGHT { type cyclicAMI; value uniform 14.3325; } TOP { type fixedValue; value uniform 14.3325; } } // ************************************************************************* // |
Reading time dependent rotating magnetic field (volVectorField) for MHD solver | kavatar | OpenFOAM Programming & Development | 1 | December 11, 2020 01:55 |
foam-extend solver steadyCompressibleMRFFoam stops with no error | artymk4 | OpenFOAM | 0 | November 15, 2018 05:16 |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 05:15 |
