changing the chemical mechanism of cumbustion in OpenFoam |
December 21, 2021, 02:02 |
Amirreza Niazmehr
Rep Power: 7 |
Hi guys, I hope you are doing well
I'm going to use one of the tutorial of OpenFoam which is concerned with cumbustion, but I want to change the chemical mechanism of cumbustion. I changed these two files: "grimech30.dat" and "thermo30.dat" in the Chemkin folder according to my mechanism but after running OpenFoam, I undestood that my changes has not been compiled and OpenFoam did not notice my changes. Can someone help me to resolve the problem? |
December 21, 2021, 03:51 |
Pls. have a look at the Sandia_LTS tutorial (e.g here https://github.com/OpenFOAM/OpenFOAM...AS/SandiaD_LTS) and the use of chemkinTofoam.
The issue you raise has been discussed in the past in this forum. See e.g. chemkinToFoam parsing issues? (v19) Please give it a look and post follow-up questions in this thread. Good luck. |
December 21, 2021, 04:16 |
Amirreza Niazmehr
Rep Power: 7 |
Hi
thanks alot, I will ask there. |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 06:54 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Can OpenFOAM simulate rubber flow when changing from its solid to liquid phase? | sur4j | OpenFOAM | 0 | September 21, 2013 06:05 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 13:50 |
