November 22, 2021, 11:05 |
decomposePar error message
Marco Aurelio Faial Rodrigues
Rep Power: 4 |
Hi everyone!
I'm a new openFoam user. I'm trying to decompose a mesh and I'm getting the following error message: "FOAM IO FALTAL ERROR (openfoam-2012) Attempt to cast type patch to type lduInterface" it's pointing to the epsilon dictionary in 0 directory. it is specifying that the error is in the boundary field "AMI2" which is of type cyclicAMI. I don't know what is going on! Please, someone could advise me how can I get more detailed information about this problem? Thank you so much! Marco |
November 25, 2021, 14:10 |
Max
Rep Power: 7 |
Could you maybe share your relevant files, so we can help you further?
December 1, 2021, 08:09 |
Rep Power: 4 |
Thank you so much to be willing to help me! Excuse me for delay in response.
In fact I already solve the problem by myself reading some parts of the Openfoam user guide. I'm following a tutorial (https://www.youtube.com/watch?v=rqrCqzuvxPY) published by Ali Ikhsanul on his youtube channel. On this tutorial, Ali theaches how to modelling a rotating propeller on Openfoam using meshes created on Salome. My problem occurred due I'm using a different version of Openfoam than Ali used on his video. Then some diference of sintaxe implemented on the dictionaries are causing the problem. Now I'm running the solver and I believe that it will finish to run next saturday! I start to run last week o wednesday! It is because I'm running on my notebook Ryzen7 that has only 4 cores. When It finished, I will upload all the configuration files, mesh and results here. Maybe it will be useful for someone. Thank you a lot one more time! Marco Last edited by marcofaial; December 1, 2021 at 08:12. Reason: English sintaxe error on my text |
December 18, 2021, 10:46 |
Solved Problem
#4 | |
Rep Power: 4 |
As I told in my last message, I solved the problem by myself. There was several mistakes in some dictionary files and I was trying to run a wrong solver. I did correct these mistakes an ran without problems. My computer tooks a lot of time to finish, it tooks 22 day! I tryed to upload my files here but the system refused to do it. Then I'm putting a link to download a zip file directly from my google drive. https://drive.google.com/file/d/1NlW...ew?usp=sharing Thank you so much! Marco |
decomposepar cyclicacmi |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
decomposePar error | chia87 | OpenFOAM Pre-Processing | 1 | May 28, 2017 15:23 |
decomposePar for custom solvers and boundary conditions | cfdopenfoam | OpenFOAM Programming & Development | 4 | October 31, 2015 09:05 |
decomposePar 4-core warning/error? | Boloar | OpenFOAM Bugs | 23 | April 8, 2014 08:57 |
decomposePar gives errors | of_user_ | OpenFOAM | 1 | July 4, 2011 05:27 |
