Velocity profile using "wallDistance" in expression |
November 12, 2021, 05:37 |
Rep Power: 7 |
I want to set a velocity profile at the inlet boundary as a function of the vertical distance to the non-planar ground surface. I'm using OpenFOAM v2106. So far I've obtained a volScalarField of wallDistance using the checkMesh utility and setting in system/fvSchemes:
wallDist { method directionalMeshWave; normal (0 0 1); } Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object wallDistance; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 0 0 0 0 0]; internalField nonuniform List<scalar> 2610223 ( 34.4376 36.2435 36.5364 ... Code:
FoamFile { version 2.0; format ascii; class volVectorField; object U; } // ============================================== // dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform (7.9 0 0); boundaryField { ground { type noSlip; } "(sides|top)" { type symmetry; value $internalField; } inlet { type uniformFixedValue; uniformValue { type expression; variables ( "z0 = 0.08" //[m] roughness length "zRef = 4.5" //[m] reference height "Uref = 7.9" //[m/s] wind speed @zRef ); expression #{ vector(Uref/log(zRef/z0)*log(wallDistance/z0), 0, 0) //[m/s] wind profile log-law #}; } } outlet { type pressureInletOutletVelocity; value $internalField; } } I've tried the solutions in wallDist already without success |
kindly help me .. i have and error at line number 147.. | m zubair | Fluent UDF and Scheme Programming | 0 | February 10, 2019 12:25 |
Expression for calculating friction velocity | Divyaprakash | Main CFD Forum | 0 | October 1, 2015 03:03 |
3d velocity profile at velocity inlet | swethaprakash | FLUENT | 3 | September 1, 2015 03:10 |
Velocity profile boundary condition | Tuca | FLOW-3D | 1 | April 23, 2013 13:02 |
Prescribed inflow velocity profile - how to? | Alan | Main CFD Forum | 10 | October 28, 2005 13:14 |
