Calling moveDynamicMesh for a second time after grid refinement |
November 11, 2021, 17:25 |
Regis
Rep Power: 14 |
I'm running into a weird issue with moveDynamicMesh. I first have a coarse grid that I conform to an STL geometry using moveDynamicMesh. That works fine. Here's a snapshot of that stage
Later on I refine the whole grid (and solution) using the topoSet/refineHexMesh combo. The grid refines as expected and passes checkMesh. The grid is still conformed as it were before on the lower resolution grid: Now, I want to re-conform the higher resolution grid to the same geometry. (In the meantine I do some local grid refinement, but that shouldn't matter.) At this point, what I expect is that the points will move very little, since only the new points need to conform to the STL file. This is where I run into issues. On the very first time step of the moveDynamicMesh solver, the new grid goes bad -- extremely high negative volume, extremely high skew -- and the moveDynamicMesh solver quickly crashes. I managed a find one very specific case that I can sort of see what is going on: In this specific run, the grid "recovers" and conforms as expected: However, I can't get it to work with any other STL or grid size. Even in this case that sort of worked, if I do one more global refinement before I call moveDynamicMesh for the second time, it crashes. In constant/dynamicMeshDict I have: Code:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libfvMotionSolvers.so"); motionSolver displacementSBRStress; diffusivity quadratic inverseDistance 1(lower); My question is-- What settings in the dynamicMeshDict can I experiment with so that I get properly conformed mesh all the time? Has anyone else experienced this behavior before? I'm running OpenFOAM 6. |
movedynamicmesh |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
