Rep Power: 5 ![]() |
Hello foamers,
I am trying to write the field average of U^2 - as a measure of field-averaged kinetic energy. So far I am able to write the field average of U by using: PHP Code:
Best, Bas |
MNM
Rep Power: 9 ![]() |
You can use swak4Foam for that...The following snippet should give you an idea...you might also need to modify it if some syntax error occurs
![]() Code:
kineticEnergyExpression { type expressionField; outputControl timeStep; outputInterval 1; fieldName kineticEnergy; variables "Ukin=sum(U*U*vol())/sum(vol());"; expression "Ukin"; autowrite true; } expression "pAverage-p"; Finally, make sure to add the corresponding libraries in the controlDict file....something like Code:
libs ( "libOpenFOAM.so" "libsimpleFunctionObjects.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" ); |
Thank you SHUBHAM9595 for your reply. Unfortunately I am running my models on a linux cluster owned by my institute and the swak4foam library is not yet installed. It will take quite a procedure to get it installed I am afraid. Are you aware of alternative ways to perform this task?
MNM
Alternatively, you can define a custom volScalarField in createFields.H (anywhere after the U ) as shown below
volScalarField KE ( IOobject ( "KE", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mag(U)*mag(U) ); AUTO_WRITE will ensure that it write the Kinetic energy field at each writing interval. Additionally, to update its value with each iteration you need to insert the following line at the end of UEqn.H Code:
KE = mag(U)*mag(U); |
Yann
Rep Power: 27 ![]() |
Hi Bas,
If you are using a relatively new version of OpenFOAM, you might be able to do it with the "multiply" function object to create the U^2 field before your volAverage function. Here is the syntax for OpenFOAM-9: Code:
functions { Usquare { type multiply; libs ("libfieldFunctionObjects.so"); fields (U U); result Usquare; executeControl writeTime; writeControl writeTime; } volFieldAverage_VA { // Mandatory entries (unmodifiable) type volFieldValue; libs ("libfieldFunctionObjects.so"); // Mandatory entries (runtime modifiable) fields (p U k Usquare); operation volAverage; regionType all; // Optional entries (runtime modifiable) weightField alpha.water; // Optional (inherited) entries writeFields no; writeToFile true; writeControl timeStep; writeInterval 1; } } Yann |
Thanks SHUBHAM9595! This is useful. I am now able to write the field for U^2 for every map output time. Eventhough it is not for every timestep (as are the volume averages of the other quantities), it is still usefull as I can determine the domain average in Paraview.
@Yann, thanks for your reply. I tried this as well. Unfortunately the version I use (v1812) does not have this functionality yet. |
fieldaverage, interfoam, kinetic energy, openfoam, volaverage |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
Converging Diverging Nozzle with dbnsTurbFoam | Saleh Abuhanieh | OpenFOAM Running, Solving & CFD | 4 | December 13, 2019 10:26 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
OpenFOAM floating point Error | upuli | OpenFOAM Programming & Development | 5 | June 20, 2016 03:19 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
