FOAM FATAL ERROR: Cannot find file "points" in directory "shell/polyMesh" |
October 29, 2021, 06:23 |
#21 |
Yann
Rep Power: 27 |
Are you running all these steps with OpenFOAM-8?
It seems there are a lot of things mixed up between OpenFOAM-8 and OpenFOAM-v2012. For instance, in the case you have provided, snappyHexMesh cannot be run with OpenFOAM-8 because you use locationsInMesh in you snappyHexMeshDict and this feature is only available in the ESI-OpenCFD branch (OpenFOAM-v2012). Yann |
October 29, 2021, 06:43 |
#22 |
amol patel
Rep Power: 4 |
Hi yann
I am using OpenFOAM-v2012. Thanks, amol |
October 29, 2021, 13:34 |
#23 |
Yann
Rep Power: 27 |
Hi Amol,
I ran your case with OpenFOAM-v2012 and here are few comments:
Yann |
[openSmoke] LaminarSMOKE compilation error | mdhfiz | OpenFOAM Community Contributions | 8 | July 2, 2024 10:32 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
