How to specify flow rate boundary condition using codedFixedValue method
Old   September 22, 2021, 11:30
Post How to specify flow rate boundary condition using codedFixedValue method
Ali
Ali_Sh is on a distinguished road
I would like to specify a small section of a wall to be outlet. So, I have used codedFixedValue to specify some meshes which centers are within a considered circle on the wall. The code will not be difficult when the boundary condition would be specified by velocity only, not the flow rate. The model is as the following photo:
The inletWalls in the code is written only for showing how flow rate can be written for a patch. How to specify this boundary condition i.e. type flowRateOutletVelocity and its value in the outletWalls section?
  |  \\    /   O peration     | Version:  v3.0+                                 |
  |   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
  version     2.0;
  format      ascii;
  class       volVectorField;
  object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
  inletWalls
    type                 flowRateInletVelocity;
    volumetricFlowRate   0.3;
    value                uniform (0 0 0);
  outletWalls
   	type            codedFixedValue;
    	redirectType    perf_outlet;
	code
            const fvPatch& boundaryPatch = patch();
            const vectorField& Cf = boundaryPatch.Cf();
            vectorField& field = *this;
            const scalar perf_r = 0.12;          // radius of the circle
 	    	forAll(Cf, faceI)
                if (
		   //(Cf[faceI].y() == 1.1) &&
                   (pow(Cf[faceI].x(),2) * pow(Cf[faceI].z(),2) <= pow(perf_r,2))     // when the circle is on Y-plane
               		field[faceI] = vector(0,1,0);   // It must be modified for specifying flowrate
  	codeOptions
       	    -I$(LIB_SRC)/finiteVolume/lnInclude \
       	    -I$(LIB_SRC)/meshTools/lnInclude
  	codeInclude
      	    #include "fvCFD.H"
      	    #include <cmath>
     	    #include <iostream>
  fixedWalls
    type            slip;
I would be grateful if someone would like to help me.
Ali_Sh is offline   Reply With Quote
boundary condition, boundary condition u, codedfixedvalue, flowrate, flowrateoutletvelocity
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Constant mass flow rate boundary condition sahm OpenFOAM 0 June 20, 2018 23:45
Volume of Flow Rate (VFR) boundary condition therockyy FLOW-3D 0 May 23, 2011 15:19
How can apply mass flow rate boundary condition? Sima Phoenics 1 December 1, 2007 19:55
