September 9, 2021, 06:55 |
setWaveField never finish
Rasmus Iwersen
Rep Power: 8 |
Hi all
I've tried to initiate my simulation, where the SetWaveField function never finish. Following is the .log file output form setWaveField: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 // using new solver syntax: pcorr { solver GAMG; tolerance 1e-07; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: pcorrFinal { solver GAMG; tolerance 1e-07; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: p_rgh { solver GAMG; tolerance 1e-07; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: p_rghFinal { solver GAMG; tolerance 1e-08; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: U { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0; } // using new solver syntax: UFinal { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0; } // using new solver syntax: gamma { solver PBiCG; preconditioner DILU; tolerance 1e-07; relTol 0; } Reading g Reading waveProperties Reading waveProperties Reading field alpha Reading field U Reading field p Setting the wave field ... And it stays like that, for at least 12 hours which to me seems a bit much... Any ideas to why this is? I suspect initial conditions being ill defined, but I havent been able to find any errors yet.. Thank you! |
September 9, 2021, 07:00 |
Rasmus Iwersen
Rep Power: 8 |
Thought i had the solution, but i didnt...
June 29, 2022, 12:11 |
Espen
Did you find a solution to this problem? I am having the same problem now :-)
June 30, 2022, 12:51 |
Rasmus Iwersen
Rep Power: 8 |
Definition of variables after /SOLU SOLVE FINISH | FredJP | ANSYS | 0 | July 13, 2017 12:51 |
wear or surface finish analysisi in abrasive flow machining in ansys fluent or CFX | doddaswamy.1801@gmail.com | ANSYS | 0 | November 17, 2016 04:45 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
Should I just finish my MS in Physics if I want to get into CFD? | e13drd | Main CFD Forum | 2 | March 17, 2014 10:08 |
Finish Time in FLOW-3D | mfaramarz | FLOW-3D | 3 | November 18, 2013 14:49 |
