August 16, 2021, 11:59 |
non-uniform mesh extrusion
yan
Rep Power: 5 |
Hi, I am trying to generating a solid baffle in the fluid domain and calculate properties on it. To achieve this, I am using "extrudetoregionmeshdict".
However, I found the generated mesh is not "flat" nor uniform. I am wondering if my settings are wrong. I hope to receive help on this. thanks! Below are the settings of "extrudetoregionmeshdict". %%%%% oneD true; sampleMode nearestPatchFace; extrudeModel linearNormal; oneDPolyPatchType empty; //wedge nLayers 8; expansionRatio 1; adaptMesh true; // directMapped for both linearNormalCoeffs { thickness 0.1; } %%%%% |
August 21, 2021, 00:00 |
yan
Rep Power: 5 |
Hi, all, I have attached some plots and contours to show what happened.
As you can see the contour contains lots of point noise. The 2d line plot shows these local data oscillations. What might be the cause of this?? |
mesh, mesh and grid |
Film cooling problem | arun1994 | OpenFOAM | 0 | October 26, 2020 10:08 |
Too high omega and k values in vortex flow simulation | thomas. | OpenFOAM Running, Solving & CFD | 9 | March 30, 2016 07:45 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
simpleFoam Floating point error (Core Dumped) | sam.ho | OpenFOAM Running, Solving & CFD | 2 | December 31, 2013 07:57 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
