OpenFoam - DynamicMesh SphericalAngularDamper value |
August 16, 2021, 10:49 |
Rep Power: 5 |
Hi CFD-friends,
At the moment I am modelling the power generation of a hydraulic turbine in OpenFOAM. The resulting power is the product of angular velocity X torque around the turbine axis. For this purpose I use a dynamic solver (sixDoFRigidBodyMotion). By means of sensitivity analysis I figured out that the results (both angular frequency and torque) are very sensitive to the value we specify for the spericalAngularDamper (see attachment). This parameter has a unit of Nms/rad. It can be seen as a friction force that acts in opposite direction with respect to the rotating motion of the turbine blades. It is defined as follows in the dynamicMeshDict: Code:
restraints { rotationDamper { //- Nms/rad // Acts against motion as friction sixDoFRigidBodyMotionRestraint sphericalAngularDamper; coeff 100; //default 10 } } Hope to hear from you. Best, Bas |
dynamicmesh, energy, power, sixdof, turbine |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 20:20 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 04:43 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
