Outlet BC: fixed outlet volumetric flow rate with reversed flow
Old   July 29, 2021, 07:17
Default Outlet BC: fixed outlet volumetric flow rate with reversed flow
juan
juanf is on a distinguished road
Hi everyone,
I am trying to find a boundary condition for an outlet patch. It should be a non uniform field, with fixed volumetric flow rate with the possibility of reverse flow rate.
The specified outlet flow should come from the integration of the flow over the patch, so, there could be reverse flow but at the end the sum of the flow on each cell will be the specified volumetric flow.
Could there be a boundary condition with this characteristics?
Thanks.
juanf is offline   Reply With Quote
boundary, conditions, flow, outlet, reverse
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
two fluid, volumetric/mass flow rate at different volume fractions Veronique Pe CFX 2 November 26, 2014 06:30
difference between inlet and outlet flow rate ?? vitorspadetoventurin OpenFOAM Running, Solving & CFD 0 November 22, 2014 21:49
Reversed flow at pressure outlet Seeker Phil FLUENT 9 January 2, 2010 06:21
