Parth
Rep Power: 5 ![]() |
Hi Guys
I am new to openfoam I just want to ask that how would you write the value of internal field in 0 folder, because in my case i only have boundary conditions for the problem, not the values of internal fields. pls help |
#2 | |
Mark Olesen
Rep Power: 40 ![]() ![]() |
Remember that for the 0/ directory or restart time, the values of internalField are your initial conditions. If you do not have any initial conditions, your problem is not correctly posed. |
beginner, cfd, openfoam |
How to write the sampled field values of a curved internal surface? | cfdcheckers | OpenFOAM Post-Processing | 3 | July 17, 2021 10:28 |
Unable to process internal faces for volume field | Jimmy Chokshi | OpenFOAM Post-Processing | 3 | January 23, 2019 04:14 |
set a fixed value to the internal field | jiahui_93 | OpenFOAM Running, Solving & CFD | 2 | October 6, 2018 10:33 |
internal field | sinatahmooresi | OpenFOAM Pre-Processing | 5 | April 2, 2016 11:42 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
