Specifying inlet and outlet on an existing geometry |
July 21, 2021, 07:35 |
Sohrab Askarli
Rep Power: 5 |
Hi all,
I've downloaded an existing stl file from the internet which is a distillation column. Now I want to specify inlet and outlet patches. However, the inlet and outlet pipes are hollow. My question is do I need to make the entrance of those cylindrical pipes filled as a surface? Please see the attached photos below: https://ibb.co/VmTCg9d https://ibb.co/QrnfYDZ https://ibb.co/sqHQd6G |
July 21, 2021, 12:50 |
Uwe Pilz
Rep Power: 15 |
You need not only "fill" the entrances but the volumen of the distiller. As I can see the stl file is the one of the container. You need a file of the interior volume. The container itself may be represented by a boundary condition (perhaps, depends on your question).
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
July 25, 2021, 02:41 |
Sohrab Askarli
Rep Power: 5 |
Dear Uwe,
Thank you so much for your reply. I decided to give up working on that file and learn FreeCad to draw the geometry myself. Regards, askarli. |
cfd, geometry |
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 04:57 |
natural convection in square cavity having inlet and outlet | sujeet | OpenFOAM Running, Solving & CFD | 1 | November 2, 2019 02:17 |
Inlet and Outlet "Static Pressure" BCs | saaghi | Main CFD Forum | 8 | November 16, 2015 15:41 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
